[postgis-devel] [PostGIS] #1902: [raster] GDAL Surfer export creates files with minY and maxY swapped in header.
PostGIS trac at osgeo.org
Thu Jul 5 13:04:50 PDT 2012
header.
 Reporter:  febi              |       Owner:  pracine
     Type:  defect            |      Status:  new
 Priority:  medium            |   Milestone:  PostGIS 2.0.2
Component:  raster            |     Version:  2.0.x
 Keywords:  raster GSBG GSAG  |
 When you try to export Golden Software Binary/ASCII grid data from PostGIS
 2.0.X with ST_AsGDALRaster function the maxY and minY are swapped in the
 header.
 In ASCII or Binary version, it should be in order of minY maxY but it is
 recorded as maxY minY. This cause problem on some software like
 Mathematica which checks these value and report as error.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1902>
