[postgis-devel] [PostGIS] #1902: [raster] GDAL Surfer export creates files with minY and maxY swapped in header.
PostGIS trac at osgeo.org
Thu Jul 5 13:42:49 PDT 2012
header.
 Reporter:  febi              |       Owner:  pracine
     Type:  defect            |      Status:  new
 Priority:  medium            |   Milestone:  PostGIS 2.0.2
Component:  raster            |     Version:  2.0.x
 Keywords:  raster GSBG GSAG  |
Comment(by febi):
 - I have the daily build for GDAL but I also tried with 1.9 stable.
 - both numbers are positive like 6404000 6401000 which should be swapped.
 - If ST_AsGDALRaster is just the "messenger" maybe this ticket should be
 closed, and I should dig into gdal formats directory.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1902#comment:2>
