[postgis-devel] [PostGIS] #1903: PostgreSQL crashes every time if I insert more than ~280 rows containing a GEOGRAPHY POINT in a table containing a GIST index
PostGIS trac at osgeo.org
Fri Jul 6 01:50:30 PDT 2012
 Reporter:  renefournier                        |       Owner:  pramsey
     Type:  defect                              |      Status:  new
 Priority:  critical                            |   Milestone:  PostGIS 2.0.2
Component:  postgis                             |     Version:  1.5.X
 Keywords:  postgis crash gist geography point  |
 Creating a table with a GIST index on the GEOGRAPHY(POINT,4326) column,
 and then inserting hundreds rows, PostgreSQL will crash every time at row
 284 (changing the order of the rows will affect at which row the crash
 occurs -- appears to be dependent on cumulative data size). If I remove
 the index, the crash never occurs.
                                        postgis_full_version
  POSTGIS="1.5.4" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.8.0, 6 March 2012"
 LIBXML="2.7.8" USE_STATS
 Log output:
 LOG:  server process (PID 1373) was terminated by signal 11: Segmentation
 fault
 LOG:  terminating any other active server processes
 WARNING:  terminating connection because of crash of another server
 process
 DETAIL:  The postmaster has commanded this server process to roll back the
 current transaction and exit, because another server process exited
 abnormally and possibly corrupted shared memory.
 HINT:  In a moment you should be able to reconnect to the database and
 repeat your command.
 LOG:  all server processes terminated; reinitializing
 LOG:  database system was interrupted; last known up at 2012-07-06
 10:46:58 CEST
 LOG:  database system was not properly shut down; automatic recovery in
 progress
 LOG:  redo starts at 0/38E6268
 LOG:  record with zero length at 0/393AB08
 LOG:  redo done at 0/393AAC8
 LOG:  last completed transaction was at log time 2012-07-06
 10:47:17.590389+02
 LOG:  database system is ready to accept connections
 LOG:  autovacuum launcher started
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1903>
