[postgis-devel] [PostGIS] #1925: lwgeom_estimate.c: In function 'LWGEOM_gist_joinsel'
PostGIS trac at osgeo.org
Wed Jul 18 03:47:00 PDT 2012
 Reporter:  koshak                                 |       Owner:  pramsey
     Type:  defect                                 |      Status:  new
 Priority:  medium                                 |   Milestone:  PostGIS 1.5.5
Component:  postgis                                |     Version:  1.5.X
 Keywords:  lwgeom_estimate.c LWGEOM_gist_joinsel  |
 Tried to compile through ports(1.5.3_2) and have the same error.
 lwgeom_estimate.c: In function 'LWGEOM_gist_joinsel':
 lwgeom_estimate.c:318: error: 'Form_pg_class' undeclared (first use in
 this function)
 lwgeom_estimate.c:318: error: (Each undeclared identifier is reported only
 once
 lwgeom_estimate.c:318: error: for each function it appears in.)
 lwgeom_estimate.c:318: error: expected ';' before 'reltup'
 lwgeom_estimate.c:319: error: 'reltup' undeclared (first use in this
 function)
 lwgeom_estimate.c:330: error: expected ';' before 'reltup'
 gmake[1]: *** [lwgeom_estimate.o] Error 1
 gmake[1]: Leaving directory `/usr/home/koshak/postgis-1.5.4/postgis'
 gmake: *** [postgis] Error 2
 *** Error code 2
 Stop in /usr/home/koshak/postgis-1.5.4.
 [root at gizmo /home/koshak/postgis-1.5.4]# uname -a
 FreeBSD gizmo 8.2-RELEASE FreeBSD 8.2-RELEASE #0: Fri Feb 18 02:24:46 UTC
 2011     root at almeida.cse.buffalo.edu:/usr/obj/usr/src/sys/GENERIC  i386
 [root at gizmo /home/koshak/postgis-1.5.4]# pkg_info | grep post
 postgresql-client-9.2.b2 PostgreSQL database (client)
 postgresql-contrib-9.2.b2 The contrib utilities from the PostgreSQL
 distribution
 postgresql-server-9.2.b2 The most advanced open-source database available
 anywhere
 Help me please :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1925>
