[postgis-devel] [PostGIS] #1925: lwgeom_estimate.c: In function 'LWGEOM_gist_joinsel'
PostGIS trac at osgeo.org
Wed Jul 18 09:36:40 PDT 2012
 Reporter:  koshak                                 |       Owner:  pramsey
     Type:  defect                                 |      Status:  new
 Priority:  medium                                 |   Milestone:  PostGIS 1.5.5
Component:  postgis                                |     Version:  1.5.X
 Keywords:  lwgeom_estimate.c LWGEOM_gist_joinsel  |
Comment(by koshak):
 Replying to [comment:4 pramsey]:
 > So you're saying that
 > /usr/local/include/postgresql/server/catalog/pg_class.h
 > exists? That's the path the compile step is searching for, but it's not
 the path you put in above.
 > How many instances of pg_config are on your system? (Look, this isn't a
 postgis issues, it's a "your system" issue. You've almost certainly got
 several installations of pgsql stuff lying around conflicting with one
 another, so your postgis build is looking for components in places they
 don't exist anymore)
 [root at gizmo /usr/home/koshak/postgis-1.5.4]# locate pg_config
 /usr/local/bin/pg_config
 /usr/local/include/ecpg_config.h
 /usr/local/include/pg_config.h
 /usr/local/include/pg_config_manual.h
 /usr/local/include/pg_config_os.h
 /usr/local/include/postgresql/server/pg_config.h
 /usr/local/include/postgresql/server/pg_config_manual.h
 /usr/local/include/postgresql/server/pg_config_os.h
 /usr/local/man/man1/pg_config.1.gz
 /usr/local/share/locale/de/LC_MESSAGES/pg_config-9.2.mo
 /usr/local/share/locale/es/LC_MESSAGES/pg_config-9.2.mo
 /usr/local/share/locale/fr/LC_MESSAGES/pg_config-9.2.mo
 /usr/local/share/locale/it/LC_MESSAGES/pg_config-9.2.mo
 /usr/local/share/locale/ja/LC_MESSAGES/pg_config-9.2.mo
 /usr/local/share/locale/ko/LC_MESSAGES/pg_config-9.2.mo
 /usr/local/share/locale/nb/LC_MESSAGES/pg_config-9.2.mo
 /usr/local/share/locale/pt_BR/LC_MESSAGES/pg_config-9.2.mo
 /usr/local/share/locale/ro/LC_MESSAGES/pg_config-9.2.mo
 /usr/local/share/locale/ru/LC_MESSAGES/pg_config-9.2.mo
 /usr/local/share/locale/sv/LC_MESSAGES/pg_config-9.2.mo
 /usr/local/share/locale/ta/LC_MESSAGES/pg_config-9.2.mo
 /usr/local/share/locale/tr/LC_MESSAGES/pg_config-9.2.mo
 /usr/local/share/locale/zh_CN/LC_MESSAGES/pg_config-9.2.mo
 /usr/local/share/locale/zh_TW/LC_MESSAGES/pg_config-9.2.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/doc/src/sgml/man1/pg_config.1
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/doc/src/sgml/ref
 /pg_config-ref.sgml
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/.gitignore
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/Makefile
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/nls.mk
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/pg_config
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/pg_config.c
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/pg_config.o
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/cs.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/cs.po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/de.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/de.po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/es.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/es.po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/fr.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/fr.po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/it.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/it.po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/ja.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/ja.po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/ko.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/ko.po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/nb.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/nb.po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/pl.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/pl.po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/pt_BR.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/pt_BR.po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/ro.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/ro.po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/ru.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/ru.po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/sv.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/sv.po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/ta.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/ta.po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/tr.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/tr.po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/zh_CN.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/zh_CN.po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/zh_TW.mo
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/bin/pg_config/po/zh_TW.po
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/include/pg_config.h
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/include/pg_config.h.in
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/include/pg_config.h.win32
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/include/pg_config_manual.h
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/include/pg_config_os.h
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/interfaces/ecpg/include/ecpg_config.h
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/interfaces/ecpg/include/ecpg_config.h.in
 /usr/ports/databases/postgresql90-client/work/postgresql-9.0.8/src/port/pg_config_paths.h
 But i wrote my pkg_info:
 [root at gizmo /usr/home/koshak]# pkg_info | grep sql
 apr-ipv6-devrandom-gdbm-db42-pgsql92-1.4.5.1.3.12_1 Apache Portability
 Library
 mysql-client-5.0.95 Multithreaded SQL database (client)
 mysql-server-5.0.95 Multithreaded SQL database (server)
 postgresql-client-9.2.b2 PostgreSQL database (client)
 postgresql-contrib-9.2.b2 The contrib utilities from the PostgreSQL
 distribution
 postgresql-server-9.2.b2 The most advanced open-source database available
 anywhere
 And output pg_config:
 [root at gizmo /home/koshak/postgis-1.5.4]# pg_config
 BINDIR = /usr/local/bin
 DOCDIR = /usr/local/share/doc/postgresql
 HTMLDIR = /usr/local/share/doc/postgresql
 INCLUDEDIR = /usr/local/include
 PKGINCLUDEDIR = /usr/local/include/postgresql
 INCLUDEDIR-SERVER = /usr/local/include/postgresql/server
 LIBDIR = /usr/local/lib
 PKGLIBDIR = /usr/local/lib/postgresql
 LOCALEDIR = /usr/local/share/locale
 MANDIR = /usr/local/man
 SHAREDIR = /usr/local/share/postgresql
 SYSCONFDIR = /usr/local/etc/postgresql
 PGXS = /usr/local/lib/postgresql/pgxs/src/makefiles/pgxs.mk
 CONFIGURE = '--with-libraries=/usr/local/lib' '--with-
 includes=/usr/local/include' '--enable-thread-safety' '--with-openssl'
 '--with-libxml' '--enable-nls' '--without-gssapi' '--prefix=/usr/local' '
 --mandir=/usr/local/man' '--infodir=/usr/local/info/' '--build=i386
 -portbld-freebsd8.2' 'build_alias=i386-portbld-freebsd8.2' 'CC=cc'
 'CFLAGS=-O2 -pipe -fno-strict-aliasing' 'LDFLAGS= -L/usr/local/lib
 -rpath=/usr/lib:/usr/local/lib' 'CPPFLAGS=' 'CPP=cpp' 'LDFLAGS_SL='
 CC = cc
 CPPFLAGS = -I/usr/local/include/libxml2 -I/usr/local/include
 -I/usr/local/include -I/usr/local/include
 CFLAGS = -O2 -pipe -fno-strict-aliasing -Wall -Wmissing-prototypes
 -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-
 format-attribute -Wformat-security -fno-strict-aliasing -fwrapv
 CFLAGS_SL = -fPIC -DPIC
 LDFLAGS = -L/usr/local/lib -rpath=/usr/lib:/usr/local/lib -L/usr/local/lib
 -L/usr/local/lib -L/usr/local/lib -Wl,--as-needed -Wl,-R'/usr/local/lib'
 LDFLAGS_EX =
 LDFLAGS_SL =
 LIBS = -lpgport -lintl -lxml2 -lssl -lcrypto -lz -lreadline -lcrypt -lm
 VERSION = PostgreSQL 9.2beta2
 I don't know how to fix that problem :( Could u help me?
 I ntried to find from where pg_class.h included, but can't find
 [root at gizmo /home/koshak/postgis-1.5.4]# grep -r pg_class * | grep -v
 "\.sql"
 extras/template_gis/postgres_lib.sh.in:                 psql -d $TDB -c
 "update pg_class set relowner=$GRID where relkind = 'S';" 2>&1 | cat >
 /dev/null
 extras/WFS_locks/WFS_locks.c:   sprintf(query,"SELECT * FROM pg_class
 WHERE relname = 'temp_lock_have_table'");
 loader/pgsql2shp.c:             sprintf(query, "SELECT oid FROM pg_class
 c, pg_namespace n WHERE c.relnamespace n.oid AND n.nspname = '%s' AND
 c.relname = '%s'", schema, table);
 WHERE relname = '%s'", table);
 loader/pgsql2shp.c:                     "pg_attribute a, pg_class c,
 pg_namespace n WHERE "
 loader/pgsql2shp.c:                     "pg_attribute a, pg_class c WHERE
 postgis/geography_estimate.c: *           Could be used to get reltuples
 from pg_class (which
 postgis/long_xact.c:    sprintf(query,"SELECT * FROM pg_class WHERE
 postgis/lwgeom_estimate.c:              Form_pg_class reltup =
 (Form_pg_class) GETSTRUCT(class_tuple);
 postgis/lwgeom_estimate.c: *      Could be used to get reltuples from
 pg_class (which
 postgis/lwgeom_estimate.c:              sprintf(query, "SELECT
 s.stanumbers1[5:8] FROM pg_statistic s, pg_class c, pg_attribute a,
 pg_namespace n WHERE c.relname = '%s' AND a.attrelid = c.oid AND a.attname
 = '%s' AND n.nspname = '%s' AND c.relnamespace = n.oid AND
 s.starelid=c.oid AND s.staattnum = a.attnum AND staattnum = attnum", tbl,
 col, nsp);
 = '%s' AND n.nspname = current_schema() AND c.relnamespace = n.oid AND
 col);
 utils/profile_intersects.pl:# get number of features from pg_class.ntuples
 utils/profile_intersects.pl:$query = 'SELECT c.reltuples FROM pg_class c,
 pg_namespace n '.
 utils/test_estimation.pl:# get number of features from pg_class.ntuples
 utils/test_estimation.pl:$query = 'SELECT c.reltuples FROM pg_class c,
 pg_namespace n '.
 utils/test_geography_estimation.pl:# get number of features from
 pg_class.ntuples
 utils/test_geography_estimation.pl:$query = 'SELECT c.reltuples FROM
 pg_class c, pg_namespace n '.
 utils/test_geography_joinestimation.pl:# get number of features from
 pg_class.ntuples
 utils/test_geography_joinestimation.pl: my $query = 'SELECT c.reltuples
 FROM pg_class c, pg_namespace n '.
 utils/test_joinestimation.pl:# get number of features from
 pg_class.ntuples
 utils/test_joinestimation.pl:   my $query = 'SELECT c.reltuples FROM
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1925#comment:6>
