[postgis-devel] [PostGIS] #1935: Signal 11: Segmentation fault
PostGIS trac at osgeo.org
Wed Jul 25 09:03:48 PDT 2012
 Reporter:  rclarke                                                    |       Owner:  pramsey
     Type:  defect                                                     |      Status:  new
 Priority:  medium                                                     |   Milestone:  PostGIS 1.5.5
Component:  postgis                                                    |     Version:  1.5.X
 Keywords:  Segmentation fault postgis crash  empty polygon signal 11  |
 postgis_full_version
  POSTGIS="1.5.5" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September
 2009" LIBXML="2.7.8" USE_STATS
 version
  PostgreSQL 9.1.4 on x86_64-unknown-linux-gnu, compiled by gcc-4.4.real
 (Debian 4.4.5-8) 4.4.5, 64-bit
 \d tbl
                                         Table "tbl"
        Column       |       Type        |
 Modifiers
  the_geom           | bytea             |
 The table is not indexed.
 ERROR:
 2012-07-25 14:21:58 BST LOG:  server process (PID 12041) was terminated by
 signal 11: Segmentation fault
 2012-07-25 14:21:58 BST LOG:  terminating any other active server
 processes
 2012-07-25 14:21:58 BST WARNING:  terminating connection because of crash
 of another server process
 2012-07-25 14:21:58 BST DETAIL:  The postmaster has commanded this server
 process to roll back the current transaction and exit, because another
 server process exited abnormally and possibly corrupted shared memory.
 2012-07-25 14:21:58 BST HINT:  In a moment you should be able to reconnect
 to the database and repeat your command.
 2012-07-25 14:21:58 BST LOG:  all server processes terminated;
 reinitializing
 2012-07-25 14:21:58 BST LOG:  database system was interrupted; last known
 up at 2012-07-25 14:14:59 BST
 2012-07-25 14:21:58 BST LOG:  database system was not properly shut down;
 automatic recovery in progress
 2012-07-25 14:21:58 BST LOG:  record with zero length at 0/30F36810
 2012-07-25 14:21:58 BST LOG:  redo is not required
 2012-07-25 14:21:58 BST LOG:  autovacuum launcher started
 2012-07-25 14:21:58 BST LOG:  database system is ready to accept
 connections
 Receiving error when running:
 select st_isvalid(the_geom) from tbl where id = 6052
 or
 select st_isvalid(the_geom::geometry) from tbl where id = 6052
 or
 select st_centroid(the_geom) from tbl where id = 6052
 On bytea field containing:
 select the_geom from tbl where id = 6052;
       the_geom
  \x010300000000000000
 select st_astext(the_geom) from tbl where id = 6052
    st_astext
  POLYGON EMPTY
 (1 row)
 I was getting the error when I was using Postgresql 8.4 and postgis  1.5.1
 also.
 The data originates from an MDB OLE Object field, imported using GDAL.
 It does not segfault when I run the following code:
 SELECT ST_IsValid(the_geom::text::geometry) FROM tbl where id = 6052
 or
  SELECT ST_IsValid(st_astext(the_geom)::geometry) FROM tbl where id =
 6052;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1935>
