[postgis-devel] [PostGIS] #1940: epsg:2065 projection is incorrect
PostGIS trac at osgeo.org
Sun Jul 29 03:53:18 PDT 2012
 Reporter:  fordfrog  |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.2
Component:  postgis   |     Version:  2.0.x
 Keywords:            |
 proj4text is not correct for this projection in spatial_ref_sys.
 here is what is returned with the installed projection:
 test=# select
 st_astext(st_transform(st_setsrid(st_geomfromtext('point(718346.93
 992772.22)'), 2065), 4326));
                 st_astext
  POINT(40.7273344172108 68.120719621313)
 (1 row)
 here is the update to the projection that fixes proj projection:
 test=# update spatial_ref_sys set proj4text = '+proj=krovak +lat_0=49.5
 +lon_0=42.5 +alpha=30.28813972222222 +k=0.9999 +x_0=-0 +y_0=-0
 +ellps=bessel +towgs84=570.8,85.7,462.8,4.998,1.587,5.261,3.56 +pm=ferro
 +to_meter=-1 +no_defs' where srid = 2065;
 UPDATE 1
 and here is the correct result:
 test=# select
                 st_astext
  POINT(14.6666442538853 50.5646644202525)
 (1 row)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1940>
