[postgis-devel] [PostGIS] #876: Better document ST_Azimuth
PostGIS trac at osgeo.org
Tue Jun 5 11:45:54 PDT 2012
  Reporter:  strk           |       Owner:  robe
      Type:  task           |      Status:  reopened
  Priority:  medium         |   Milestone:  PostGIS 2.0.0
 Component:  documentation  |     Version:  trunk
Resolution:                 |    Keywords:
Comment(by robe):
 wrog,
 Your explanation sounds fine to strk.  I have too much of a headache
 thinking about azimuth to have an opinion on the matter. You want to
 provide a patch for the documentation and we'll apply it?  The image was
 generated with wkt in html/image_src/st_azimuth* files so a bit tricky to
 add arrows.  We can accept an alternative image even if not wkt format --
 just keep around the same size.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/876#comment:3>
