[postgis-devel] [PostGIS] #1802: Ensure interruptability of long-running calls
PostGIS trac at osgeo.org
Tue Jun 5 13:40:24 PDT 2012
 Reporter:  strk     |       Owner:  strk
     Type:  task     |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by strk):
 Mark: maybe you don't feel the problem as you never had it.
 Try running this query:
 set statement_timeout to 1000;
 select st_buffer(st_collect(geom), 1e5) from ( select
 (st_dumppoints(st_buffer(st_point(0,0), 1e4, 150))).geom ) as foo;
 And see if it stops, as requested, after one second.
 Oh, you might need to hard-kill the backend to take back control of your
 machine, so be prepared...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1802#comment:16>
