[postgis-devel] [PostGIS] #1853: Can't make check under mingw345
PostGIS trac at osgeo.org
Wed Jun 6 21:24:24 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Since the perl change I have been unable to successfully make check.  It
 is failing on all the loader tests.  Though the other tests are fine.
 I have to test on my mingw64 as I was having other issues with make check
 failing on xml processing which may have nothing to do with perl change.
 the loader.err file shows:
 Unable to open .shp or .SHP.
 .shp: dbf file (.dbf) can not be opened.
 and there are a whole bunch of tmp files with content like
 PGCOPY
 ΓΏ
 This is testing against 9.2 beta1.  Though I don't recall having issue
 pre-perl when I tested this.  I'll check my other versions next to see if
 its a 9.2 specific thing.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1853>
