[postgis-devel] [PostGIS] #1855: 'SQL/MM Spatial exception - curve not simple' exception at adding two polygons
PostGIS trac at osgeo.org
Thu Jun 7 08:33:23 PDT 2012
polygons
 Reporter:  wimned    |       Owner:  strk
     Type:  defect    |      Status:  assigned
 Priority:  medium    |   Milestone:  PostGIS 2.0.1
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Changes (by strk):
  * status:  new => assigned
Comment:
 Ok, I just tested your functions and could reproduce the problem.
 This is with POSTGIS="2.0.1SVN r9850" GEOS="3.4.0dev-CAPI-1.8.0 r3670"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1855#comment:4>
