[postgis-devel] [PostGIS] #1822: topology won't install on PostgreSQL 9.2beta1
PostGIS trac at osgeo.org
Thu Jun 7 11:13:48 PDT 2012
  Reporter:  robe      |       Owner:  strk
      Type:  defect    |      Status:  reopened
  Priority:  blocker   |   Milestone:  PostGIS 2.0.1
 Component:  topology  |     Version:  2.0.x
Resolution:            |    Keywords:
Comment(by robe):
 I only see it at the end and I think I even added it
 http://trac.osgeo.org/postgis/browser/trunk/topology/topology.sql.in.c?rev=9748#L1987
 (and I think I added that because I needed it for the SQLManagement to
 know whether I can DO or not DO. We won't be needing that check anymore
 for 2.1.0 once you upgrade from your crappy 8.4 and 9.0 is the minor.
 Then I can be DOing all I want :).
 does the fact that your check happens before the variable is defined
 matter?
 Well the POSTGIS_PGSQL_VERSION I presume is something screwy with our
 parsing.
 The version is 9.2beta1
 Seems like its picking up the 1 part as part of version number.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1822#comment:8>
