[postgis-devel] [PostGIS] #1856: reverse geocoder rating setting for prefer numbered highway name
PostGIS trac at osgeo.org
Thu Jun 7 21:23:41 PDT 2012
  Reporter:  robe            |       Owner:  robe
      Type:  enhancement     |      Status:  closed
  Priority:  medium          |   Milestone:  PostGIS 2.1.0
 Component:  tiger geocoder  |     Version:  trunk
Resolution:  fixed           |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 completed at r9861.
 To prefer numbered name you would do
 SELECT set_geocode_setting('reverse_geocode_numbered_roads', '1');
 SELECT pprint_addy((reverse_geocode('POINT(-71.355863
 42.602466)'::geometry)).addy[1])
 Gives output of:
 I- 495, Chelmsford, MA 01824
 To prefer local name
 SELECT set_geocode_setting('reverse_geocode_numbered_roads', '2');
 Example:
 42.602466)'::geometry)).addy[1]);
 Hwy Blue Star Memorial, Chelmsford, MA 01824
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1856#comment:1>
