[postgis-devel] [PostGIS] #1855: 'SQL/MM Spatial exception - curve not simple' exception at adding two polygons
PostGIS trac at osgeo.org
Fri Jun 8 02:54:14 PDT 2012
polygons
 Reporter:  wimned    |       Owner:  strk
     Type:  defect    |      Status:  assigned
 Priority:  medium    |   Milestone:  PostGIS 2.0.1
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by strk):
 Extremely simplified case exposing the bug:
 SELECT CreateTopology('wimpy');
 SELECT topogeo_AddLinestring('wimpy', 'LINESTRING(0 0, 10 0, 0 1)', 2);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1855#comment:7>
