[postgis-devel] [PostGIS] #1857: AddEdgeModFace and AddEdgeNewFace fail to detect mismatch start/endpoint param
PostGIS trac at osgeo.org
Fri Jun 8 03:52:29 PDT 2012
param
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
 If you specify the same node number for start and end node but then pass
 an edge where the first point matches the node and the second doesn't what
 you get is the confusing error message in #1774 (lwpoly_from_lwlines:
 shell must have at least 4 points)
 Instead, you should get "end node not geometry end point" or something
 like that.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1857>
