[postgis-devel] shp2pgsql - Cannot use both -D and -r
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Fri Jun 8 05:47:20 PDT 2012
On 16/05/12 07:25, Lauri Kajan wrote:
> Hi all,
> When trying to import shape files with a command:
> shp2pgsql -c -D -s 3067 -i -N skip -W CP1252 C:\myshape.shp mytable |
> psql -d postgis
> I got an error "Cannot use both -D and -r". What is the -r parameter?
> Should it be -s?
> I removed the s parameter and then it worked. But now all my tables
> are without srid.
> I think the same command has worked before.
> Why the srid setting has been disabled when using dump or is this a bug?
> I had the latest windows version from the Stack Builder.
> -Lauri
Hi Lauri,
I've had a look at this, and found a better way of parsing the valid
argument combinations in shp2pgsql. It will need someone to double-check
this on Windows though.
ATB,
Mark.
