[postgis-devel] [PostGIS] #1815: spatial_ref_sys table cannot be dumped using pg_dump when installed as an extension
PostGIS trac at osgeo.org
Mon Jun 11 04:49:58 PDT 2012
extension
  Reporter:  chander        |       Owner:  robe
      Type:  defect         |      Status:  closed
  Priority:  high           |   Milestone:  PostGIS 2.0.1
 Component:  documentation  |     Version:  2.0.x
Resolution:  fixed          |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 put in a warning note about this behavior and that you need to backup the
 whole database for these customs to be backed up.
 r9876 for PostGIS 2.0  and r9875 for PostGIS 2.1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1815#comment:6>
