[postgis-devel] [PostGIS] #1779: Make install is not installing comments sql files
PostGIS trac at osgeo.org
Mon Jun 11 11:30:03 PDT 2012
  Reporter:  jomarlla               |       Owner:  strk
      Type:  defect                 |      Status:  closed
  Priority:  medium                 |   Milestone:  PostGIS 2.0.1
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:  fixed                  |    Keywords:
Changes (by strk):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 r9885 will install them when possible. r9886 will also build them, always
 when possible.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1779#comment:4>
