[postgis-devel] [PostGIS] #1861: Can't compile under mingw with geos 3.4.0 dev
PostGIS trac at osgeo.org
Tue Jun 12 04:34:55 PDT 2012
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 strk,
 I think your interruptibility changes are screwing me.  Now even with the
 latest geos trunk (3673) I can't get either of my mingw environments to
 compile PostGIS trunk.  Perhaps it's just a missing condition.
 This is the error I get under my mingw64
 postgis_module.c: In function '_PG_init':
 postgis_module.c:54:3: error: too few arguments to function
 'GEOS_interruptRegisterCallback'
 c:/ming64/projects/geos/rel-3.4.0SVNw64/include/geos_c.h:159:40: note:
 declared
 here
 postgis_module.c: At top level:
 postgis_module.c:35:13: warning: 'geosInterruptCallback' defined but not
 used
 make[1]: *** [postgis_module.o] Error 1
 make[1]: Leaving directory `/c/ming64/projects/postgis/2.1/postgis'
 make: *** [all] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1861>
