[postgis-devel] [PostGIS] #1866: cunit regression failure on mingw32
PostGIS trac at osgeo.org
Wed Jun 13 23:58:58 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 strk -- I think I can compile again against geos 3.4.0 (at least onf
 32-bit ).  Still need to test 64-bit install.  However I am getting a
 regression failure.
  Test: test_lwgeom_make_valid ... FAILED
     1. cu_clean.c:58  -
 CU_ASSERT_STRING_EQUAL(ewkt,"GEOMETRYCOLLECTION(POINT(0
 0),MULTIPOLYGON(((5 5,0 0,0 10,5 5)),((5 5,10 10,10 0,5 5))),LINESTRING(10
 0,10 10))")
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1866>
