[postgis-devel] [PostGIS] #1866: cunit regression failure on mingw32
PostGIS trac at osgeo.org
Thu Jun 14 11:24:20 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 For the record fails on my mingw64 as well.  See Paul some things are the
 same. I have more issues iwth testing agains EDB builds than against mingw
 compiled builds. :)
 strk -- this is output from min mingw64-- I assume it would be the same
 for my old mingw32.
 Suite: clean
   Test: test_lwgeom_make_valid ...c = GEOMETRYCOLLECTION(POINT(0
 0),MULTIPOLYGON
 (((5 5,10 10,10 0,5 5)),((5 5,0 0,0 10,5 5))),LINESTRING(10 0,10 10))
 FAILED
     1. cu_clean.c:58  -
 CU_ASSERT_STRING_EQUAL(ewkt,"GEOMETRYCOLLECTION(POINT(0
 0),MULTIPOLYGON(((5 5,0 0,0 10,5 5)),((5 5,10 10,10 0,5 5))),LINESTRING(10
 0,10
 10))")
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1866#comment:2>
