[postgis-devel] [PostGIS] #1855: 'SQL/MM Spatial exception - curve not simple' exception at adding two polygons
PostGIS trac at osgeo.org
Fri Jun 15 02:43:43 PDT 2012
polygons
 Reporter:  wimned    |       Owner:  strk
     Type:  defect    |      Status:  assigned
 Priority:  medium    |   Milestone:  PostGIS 2.0.2
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Changes (by strk):
  * milestone:  PostGIS 2.0.1 => PostGIS 2.0.2
Comment:
 won't be working on this in time for 2.0.1 (and not even sure it'll ever
 work in the 2.0 branch)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1855#comment:10>
