[postgis-devel] Is trunk broken?
Paul Ramsey pramsey at opengeo.org
Mon Jun 18 10:27:55 PDT 2012
Still? I just did a clean check-out of trunk and built / checked.
postgis and raster both built and checked fine.
P.
On Sat, Jun 16, 2012 at 6:07 PM,  <maplabs at light42.com> wrote:
> Hi Bborie -
>   for rev 9921, postgis-2.1.so shows up for me
> in /usr/lib/postgresql/9.1/lib/
> it appears to be linking fine.. ldd shows
> linux-vdso.so.1 =>  (0x00007fff4b1ff000) libgeos_c.so.1 =>
> /usr/local/lib/libgeos_c.so.1 (0x00007fb9387a2000) libproj.so.0 =>
> /usr/local/lib/libproj.so.0 (0x00007fb938550000) libjson.so.0 =>
> /usr/lib/x86_64-linux-gnu/libjson.so.0 (0x00007fb938347000) libxml2.so.2 =>
> /usr/lib/x86_64-linux-gnu/libxml2.so.2 (0x00007fb937fec000) libc.so.6 =>
> /lib/x86_64-linux-gnu/libc.so.6 (0x00007fb937c2f000) libgeos-3.4.0dev.so =>
> /usr/local/lib/libgeos-3.4.0dev.so (0x00007fb9378a3000) libstdc++.so.6 =>
> /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fb9375a3000) libgcc_s.so.1
> => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fb93738d000) libm.so.6 =>
> /lib/x86_64-linux-gnu/libm.so.6 (0x00007fb937092000) libdl.so.2 =>
> /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fb936e8e000) libz.so.1 =>
> /lib/x86_64-linux-gnu/libz.so.1 (0x00007fb936c77000)
> /lib64/ld-linux-x86-64.so.2 (0x00007fb938c6b000)
>   but yes, I get an undefined symb9l early in make check, too
> ERROR:  could not load library
> "/pinedisk/srcsAced/postgis_trunk/regress/00-regress-install/lib/postgis-2.1.so":
> /pinedisk/srcsAced/postgis_trunk/regress/00-regress-install/lib/postgis-2.1.so:
> undefined symbol: lwgeom_calculate_circ_tree
>   -Brian
> On Sat, 16 Jun 2012 14:52:12 -0700, Bborie Park <dustymugs at gmail.com> wrote:
> I'm trying to run regression tests on trunk r9919 and am unable to.
>> The error I'm getting from regress_log is:
>> psql:/home/software/geo/postgis-git/regress/00-regress-install/share/contrib/postgis/postgis.sql:47:
>> "/home/software/geo/postgis-git/regress/00-regress-install/lib/postgis-2.1.so":
>> /home/software/geo/postgis-git/regress/00-regress-install/lib/postgis-2.1.so:
>> Trunk compiles just fine though.
>> -bborie
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
