[postgis-devel] [PostGIS] #1878: shp2pgsql-gui: Column contents have tangled values
PostGIS trac at osgeo.org
Tue Jun 19 20:10:27 PDT 2012
  Reporter:  bmmpxf         |       Owner:  mcayland
      Type:  defect         |      Status:  closed
  Priority:  medium         |   Milestone:  PostGIS 2.0.1
 Component:  loader/dumper  |     Version:  2.0.x
Resolution:  duplicate      |    Keywords:
Comment(by robe):
 bmmpxf -- we have a newer windows build you can download from here:
 http://www.postgis.org/download/windows/experimental.php
 If you don't want to test out the whole package -- just use the POSTGIS
 ESRI Shapefile GUI ones which just have the postgisgui folder.  You can
 replace your current folder with this one.
 Mark -- I just noticed that the revision number no longer shows on the
 About -- it just shows PostGIS 2.0.1SVN.  Is that an intentional change?
 I liked it a bit better the other ways since I do make interim builds and
 gives a sense of which release in case people have issues.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1878#comment:3>
