[postgis-devel] [PostGIS] #1878: shp2pgsql-gui: Column contents have tangled values
PostGIS trac at osgeo.org
Wed Jun 20 09:36:08 PDT 2012
  Reporter:  bmmpxf         |       Owner:  mcayland
      Type:  defect         |      Status:  reopened
  Priority:  medium         |   Milestone:  PostGIS 2.0.1
 Component:  loader/dumper  |     Version:  2.0.x
Resolution:                 |    Keywords:
Changes (by bmmpxf):
  * status:  closed => reopened
  * resolution:  duplicate =>
Comment:
 Hi there.  Okay, I grabbed the experimental build (32bit) from this link:
 http://www.postgis.org/download/windows/extras/postgisgui_pgadmin-2.0.1SVNw32.zip
 The copied field issue has gone away, which is good.  Now, however, when I
 click on the table name to edit it, and them click on the Schema name to
 its left, the entire entry row will immediately disappear.  So something
 is still amiss.
 As an aside, I'm curious why the new UI is inflexible (no app or column
 resizing allowed for example, except by the app itself).  I made a list of
 desired UI/UX improvements for this tool, so if this is the proper forum
 for such things, I'd gladly make individual tickets for them.
 Thanks again for all your help.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1878#comment:4>
