[postgis-devel] [PostGIS] #1759: shp2pgsql st_transform not unique requires casting
PostGIS trac at osgeo.org
Wed Jun 20 16:08:17 PDT 2012
  Reporter:  robe           |       Owner:  mcayland
      Type:  defect         |      Status:  reopened
  Priority:  blocker        |   Milestone:  PostGIS 2.0.1
 Component:  loader/dumper  |     Version:  2.0.x
Resolution:                 |    Keywords:
Changes (by robe):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Evidentally I missed testing this on geography:
 I tested with this command:
 %SHP2PGSQL% -c -s 4269:4326 -G -g geog  -W "latin1" tl_2010_42_zcta510
 tiger_staging.zcta510_42 > zip.sql
 And it needs to cast the geometry first before transforming so I guess you
 need to make the same change for geography.
 Note:
 It produces
 ST_Transform('gubblygook',4326)::geography
 and needs to produce:
 ST_Transform('gubblygook'::geometry,4326)::geography
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1759#comment:6>
