[postgis-devel] [PostGIS] #1882: regress failure st_asraster, st_resample on mingw64 9.1 mingw64 built 9.1
PostGIS trac at osgeo.org
Thu Jun 21 14:57:22 PDT 2012
  Reporter:  robe        |       Owner:  dustymugs
      Type:  defect      |      Status:  closed
  Priority:  medium      |   Milestone:  PostGIS 2.0.1
 Component:  raster      |     Version:  2.0.x
Resolution:  worksforme  |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => worksforme
Comment:
 I assume your changes have nothing to do with this ticket dusty aside from
 maybe catching when GDAL Data is not configured right.  Anyrate on my
 regular mingw64 build system for 9.1, the raster tests all pass so I'll
 dismiss this as a non-issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1882#comment:4>
