[postgis-devel] [PostGIS] #1883: Geocoder install fails trying to run create_census_base_tables()
PostGIS trac at osgeo.org
Thu Jun 21 16:46:02 PDT 2012
 Reporter:  bpanulla        |       Owner:  robe
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.1
Component:  tiger geocoder  |     Version:  2.0.x
 Keywords:                  |
 I did a clean install of PostGIS 2.0 from RPM. When I started to set up
 the tiger2010 geocoder I saw an error in the output of
 [source:trunk/extras/tiger_geocoder/tiger_2010/create_geocode.sh
 create_geocode.sh]
 SELECT tiger.create_census_base_tables();: No such file or directory
 On line 20:
 ${PSQL_CMD}  -d "${THEDB}" -f "SELECT tiger.create_census_base_tables();"
 That should probably be '''-c''' to run inline SQL rather than '''-f'''.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1883>
