[postgis-devel] [PostGIS] #1883: Geocoder install fails trying to run create_census_base_tables()
PostGIS trac at osgeo.org
Thu Jun 21 22:53:32 PDT 2012
  Reporter:  bpanulla        |       Owner:  robe
      Type:  defect          |      Status:  closed
  Priority:  medium          |   Milestone:  PostGIS 2.0.1
 Component:  tiger geocoder  |     Version:  2.0.x
Resolution:  fixed           |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Thanks for the catch. Fixed at r9972 for 2.0 and r9973 for 2.1.  I guess I
 missed it since I'm on windows and I guess I forgot to change the Linux
 script when I corrected the windows one.
 FWIW:  The PostGIS 2.1 (trunk), has tiger2011.  It will work just fine
 with PostGIS 2.0.  In fact I'm using it against my PostGIS 2.0 production
 install.
 If you are starting out, you might want to go with that one as I hear
 they've made many improvements to the tiger 2011 dataset.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1883#comment:1>
