[postgis-devel] [PostGIS] #1881: shp2pgsql-gui -- editing a field sometimes triggers removing row
PostGIS trac at osgeo.org
Fri Jun 22 05:05:37 PDT 2012
  Reporter:  robe           |       Owner:  mcayland
      Type:  defect         |      Status:  closed
  Priority:  medium         |   Milestone:  PostGIS 2.0.2
 Component:  loader/dumper  |     Version:  2.0.x
Resolution:  fixed          |    Keywords:
Comment(by mcayland):
 Originally I allowed the first (filename) column to be resized but
 automatically resized all of the others, so perhaps your 32-bit build is
 not up to date?
 Also: what version of GTK are you building against? They've asked me to
 try with a newer version to see if the bug is still there :/
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1881#comment:10>
