[postgis-devel] [PostGIS] #1881: shp2pgsql-gui -- editing a field sometimes triggers removing row
PostGIS trac at osgeo.org
Fri Jun 22 06:26:44 PDT 2012
  Reporter:  robe           |       Owner:  mcayland
      Type:  defect         |      Status:  closed
  Priority:  medium         |   Milestone:  PostGIS 2.0.1
 Component:  loader/dumper  |     Version:  2.0.x
Resolution:  fixed          |    Keywords:
Comment(by robe):
 mcayland,
 I think you are right about my win32 build being older (so bmmpxf, don't
 bother testing the attached file).  I must have built it a little bit
 before you committed.  It exhibits the bug.  I thought the fact I could
 add and enter into the table field without it removing meant it was fixed,
 but now I realize the issue only happens if I actually try to overwrite
 the field content.  My mingw64 doesn't exhibit this bug anymore though it
 did before (and the old mingw64 backup I have doesn't allow stretching the
 other columns).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1881#comment:12>
