[postgis-devel] [PostGIS] #1828: Estimate returned by geography_gist_selectivity results in slow query plan for ST_DWithin
PostGIS trac at osgeo.org
Fri Jun 22 12:04:20 PDT 2012
for ST_DWithin
 Reporter:  realityexists  |       Owner:  mcayland
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.2
Component:  postgis        |     Version:  2.0.x
 Keywords:                 |
Comment(by pramsey):
 And so if you change the estimate for <const> && <const> to 1.0
 (geography_estimate.c:540), you get the correct estimate on our overall
 DWithin query.
          * We are working on two constants..
          * TODO: check if expression is true,
          *       returned set would be either
          *       the whole or none.
         if ( ! IsA(self, Var) )
                 POSTGIS_DEBUG(3, " no variable argument ? - returning
 default selectivity");
                 PG_RETURN_FLOAT8(1.0);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1828#comment:34>
