[postgis-devel] type agg_samealignment does not exist
dustymugs dustymugs at gmail.com
Mon Jun 25 15:00:00 PDT 2012
Salvatore,
I'm guessing you're looking to move up from PostGIS 2.0.x to PostGIS
-trunk?  If so, you can't use rtpostgis_upgrade_20_minor.sql as-is since
that upgrade file is for upgrading within the 2.0 code base.
Since you're trying to use -trunk, I'm assuming you don't mind some
risk.  You can still use rtpostgis_upgrade_20_minor.sql with the
following modification though...
Look for the following function:
CREATE OR REPLACE FUNCTION _st_samealignment_transfn(agg
agg_samealignment, rast raster)
Before that line, provide the following:
CREATE TYPE agg_samealignment AS (
    refraster raster,
    aligned boolean
That should take care of the agg_samealignment missing issue.
-bborie
On 06/25/2012 02:48 PM, Salvatore Larosa wrote:
> Il giorno sab, 23/06/2012 alle 15.30 -0400, Paragon Corporation ha
> scritto:
>> Our 2.1 upgrade is in a bit of a mess at the moment.
>> See ticket:
>> http://trac.osgeo.org/postgis/ticket/1850
> So, must I return to the previous version (2.0.1 or 2.0) ?
