[postgis-devel] type agg_samealignment does not exist
Sandro Santilli strk at keybit.net
Tue Jun 26 05:36:18 PDT 2012
On Tue, Jun 26, 2012 at 02:27:17PM +0200, Salvatore Larosa wrote:
> Il giorno mar, 26/06/2012 alle 12.13 +0200, Sandro Santilli ha scritto:
> > "make uninstall" drops the libpostgis-2.0.so, doesn't know it came from an
> > older install. Re-install 2.0.0 and you should be fine.
> Well, maybe I got it!
> Since I've always used the trunk version, when it was tagged as 2.1 the
> two libraries coexisted. Then with make uninstall I deleted
> libpostgis-2.0.so and accessing the db throws that error!
> then I think I need to recreate my DBs with 2.1! so?
Either so or you'd need to upgrade the definition of all postgis versions
to look for libpostgis-2.1.so rather than libpostgis-2.0.so -- this is
basically what the upgrade scripts do.
--strk;
 Sent from our free software
 http://www.gnu.org/philosophy/free-sw.html
