[postgis-devel] [PostGIS] #1890: Configure finds sometimes older libraries
PostGIS trac at osgeo.org
Tue Jun 26 06:15:38 PDT 2012
 Reporter:  janh                    |       Owner:  strk
     Type:  defect                  |      Status:  new
 Priority:  medium                  |   Milestone:  PostGIS 2.0.1
Component:  postgis                 |     Version:  2.0.x
 Keywords:  Non-standard Configure  |
 When configuring for non-standard installation locations, (CFLAGS=...
 LDFLAGS=... configure) the header files and libraries in those locations
 will be searched before the source tree. This means that a  relative
 include path, like "liblwgeom.h", will be retrieved from the older
 installed version. A possible solution would be to give the path relative
 to the souce code (" ../liblwgeom/liblwgeom.h"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1890>
