[postgis-devel] [PostGIS] #1048: [raster] Coverage version of stats functions should be aggregates
PostGIS trac at osgeo.org
Fri Jun 29 11:58:50 PDT 2012
 Reporter:  pracine      |       Owner:  pracine
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.0
Component:  raster       |     Version:  trunk
 Keywords:               |
Changes (by dustymugs):
  * milestone:  PostGIS Future => PostGIS 2.1.0
Comment:
 Just some notes copied for raster/TODO...
 Instead of stats functions using tablename, columnname for a coverage, it
 should be using aggregate functions.  This change isn't too significant
 for
 most of the stats functions.  BUT, the histogram and quantile functions
 will
 need to be rewritten to use 1-pass algorithms that do not require prior
 knowledge of the size of the incoming stream.  The current coverage
 quantile
 function is a 1-pass algorithm but requires prior knowledge of the size of
 the stream.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1048#comment:6>
