[postgis-devel] [PostGIS] #1630: upgrade from alpha6 to alpha7SVN: wktgeomval type can't be dropped; cannot change input parameter nodata
PostGIS trac at osgeo.org
Thu Mar 1 00:14:47 PST 2012
  Reporter:  robe                   |       Owner:  strk
      Type:  defect                 |      Status:  reopened
  Priority:  blocker                |   Milestone:  PostGIS 2.0.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:                         |    Keywords:
Changes (by robe):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 I'm afraid there is still an issue here, but not sure if it's an issue
 going from alpha6.  I just tried upgrading an alpha5 to beta1 with
 extensions and get this:
 Cannot change name of input parameter "nodata".  Use Drop function.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1630#comment:9>
