[postgis-devel] [PostGIS] #1642: cannot make comments
PostGIS trac at osgeo.org
Thu Mar 1 03:05:58 PST 2012
 Reporter:  3nids                  |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  2.0.x
 Keywords:                         |
Comment(by strk):
 Since a few revision the default is not allowing you to fetch data from
 the net.
 If you really want to allow that you can append "XSLTPROCFLAGS=" to your
 make call.
 But I'd recommend figuring out where you have isonum.ent. I have it here:
 w3-dtd-mathml: /usr/share/xml/schema/w3c/mathml/dtd/isonum.ent
 Would you feel like compiling a patch for README.postgis to list the
 additional requirements ?
 We could actually tweak ./configure to warn and suggest package names
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1642#comment:1>
