[postgis-devel] [PostGIS] #1641: SQL/MM Spatial exception - geometry crosses an edge
PostGIS trac at osgeo.org
Thu Mar 1 06:26:29 PST 2012
 Reporter:  lrssvt    |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by strk):
 Replying to [comment:1 lrssvt]:
 > How do I determine the correct tolerance?
 So to answer this again (I didn't really answer before).
 I suggest you use the value that you do tollerate in your topology.
 Millimeter precision is enough and your units are meters ? Use 1e-3 !
 There is support for specifying a topology-wide tolerance (it's an
 argument to CreateTopology)
 but no funtion currently really uses it at the moment. You can surely use
 it as a reference.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1641#comment:6>
