[postgis-devel] [PostGIS] #1639: [raster] MapAlgebraExpr can't handle conditions
PostGIS trac at osgeo.org
Thu Mar 1 07:46:50 PST 2012
 Reporter:  nicklas  |       Owner:  pracine
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  raster   |     Version:  trunk
 Keywords:           |
Comment(by dustymugs):
 As for two raster MapAlgebraExpr, it works as expected...
 DROP TYPE IF EXISTS cellset CASCADE;
 CREATE TYPE cellset AS (
         x integer,
         y integer,
         value double precision
 CREATE OR REPLACE FUNCTION dump_cells(rast raster, band int DEFAULT 1)
         RETURNS SETOF cellset
         AS $$
         DECLARE
                 r cellset%rowtype;
                 rows int;
                 cols int;
         BEGIN
                 SELECT width, height INTO rows, cols FROM
 ST_Metadata(rast);
                 FOR r IN SELECT x, y, ST_Value(rast, band, x, y)
                         FROM generate_series(1, rows) AS x
                         CROSS JOIN generate_series(1, cols) AS y
                         LOOP
                         RETURN NEXT r;
                 END LOOP;
         END;
         LANGUAGE 'plpgsql';
 WITH foo AS (
         SELECT
                 ST_AddBand(
                         ST_MakeEmptyRaster(5, 5, 0, 0, 1, -1, 0, 0, 0)
                         , '8BUI'::text, 1, 0
         AS rast
 SELECT dump_cells(rast)
 FROM (
         SELECT
                 ST_MapAlgebraExpr(rast, rast, 'CASE WHEN [rast1.x] % 2 = 0
 AND [rast1.y] % 2 = 0 AND [rast2.x] % 2 = 0 AND [rast2.y] % 2 = 0 THEN
 NULL ELSE 128. END') AS rast
         FROM foo
 ) bar
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1639#comment:4>
