[postgis-devel] [PostGIS] #1639: [raster] MapAlgebraExpr can't handle conditions
PostGIS trac at osgeo.org
Thu Mar 1 12:58:35 PST 2012
 Reporter:  nicklas  |       Owner:  pracine
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  raster   |     Version:  trunk
 Keywords:           |
Comment(by nicklas):
 Yes, I can confirm that 2-rasterworks as expected.
 The reason I said it didn't was that I tested to make an expression like
 this:
 (([rast1]-[rast2])>50)::int
 and expected to get 0 and 1 for true or false as I do in a normal SELECT
 query. Bu that didn't work.
 I also tried to populate pixeltype '1BB' with the above without the cast
 to integer but that didn't work either.
 How to populate boolean pixeltype?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1639#comment:6>
