[postgis-devel] [PostGIS] #1639: [raster] MapAlgebraExpr can't handle conditions
PostGIS trac at osgeo.org
Fri Mar 2 02:40:36 PST 2012
 Reporter:  nicklas  |       Owner:  pracine
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  raster   |     Version:  trunk
 Keywords:           |
Comment(by nicklas):
 Great Pierre
 almost there
 First 1-raster version is still not working as I understand dustymugs
 comments above.
 Second:
 You are right I misunderstood things, but still, the casts doesn't make
 sense.
 If I cast to Integer and put it in '8BSI' like this:
 WITH foo AS (
         SELECT
                 ST_MapAlgebraExpr(a.rast, b.rast, '(([rast1]-[rast2]) >
 5)::int', '8BSI') AS rast
         FROM test_mapalgebra a
         CROSS JOIN test_mapalgebra b
         WHERE a.rid = 1
                 AND b.rid = 2
 SELECT
         (ST_BandMetadata(rast)).*,
         (ST_SummaryStats(rast)).*
 FROM foo;
 Then I would expect the false results to show as 0, right?
 But I still get the same result (nodata as I have learned now :-) )
 I also wonder if something is wrong because of performance. I am using
 this expressions to find clear cuttings (I will give a PostGIS talk next
 week and will show the functionality)
 To do this calculation in PostGIS it takes about 45 seconds, but in QGIS
 with the same images as geotiff it takes less than 2 seconds.
 But it can be because PostGIS can't gain fully from the SATA3 ssd on this
 box while maybe the file based  gdal calculation through QGIS can?
 Or is it some casts that is giving a false bottleneck?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1639#comment:14>
