[postgis-devel] [PostGIS] #1641: TopoGeo_addLineString: SQL/MM Spatial exception - geometry crosses an edge
PostGIS trac at osgeo.org
Fri Mar 2 04:52:30 PST 2012
 Reporter:  lrssvt    |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.1.0
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by lrssvt):
 Replying to [comment:13 strk]:
 > I start thinking that's why GRASS wants you to create those "locations"
 before use :P
 ESRI also, in topology builder, use a default tolerance [1] to 0.0001!
 I think for the same reason, perhaps!
 [1] -
 [http://jiangsuimage.com/ArcGIS/Manager/Help/index.htm#geodatabases/topology_in_arcgis.htm]
 Do you think you can follow the same approach?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1641#comment:15>
