[postgis-devel] [PostGIS] #1630: upgrade from alpha6 to beta1: wktgeomval type can't be dropped; cannot change input parameter nodata; can't drop raster_columns
PostGIS trac at osgeo.org
Fri Mar 2 06:11:18 PST 2012
  Reporter:  robe                   |       Owner:  strk
      Type:  defect                 |      Status:  reopened
  Priority:  blocker                |   Milestone:  PostGIS 2.0.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:                         |    Keywords:
Comment(by robe):
 Okay I think I fixed the drop raster_columns / wktgeomval issue in r9382.
 Not sure why I didn't run into this before.  I thought I tested it earlier
 on.
 Anyrate I suspect this is a bug in the extension model itself since to fix
 I had to drop sideline types created by the postgresql system which we
 didn't explicitly create but depend on things we did create. Seems silly
 to me it doesn't drop them as part of the ALTER EXTENSION .. DROP VIEW ,
 DROP TYPE process.  I'll report upstream to confirm
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1630#comment:12>
