[postgis-devel] [PostGIS] #1618: [raster] ST_Transform to SRID 3978 produce wrong results
PostGIS trac at osgeo.org
Fri Mar 2 10:29:59 PST 2012
 Reporter:  pracine  |       Owner:  dustymugs
     Type:  defect   |      Status:  assigned
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  raster   |     Version:  trunk
 Keywords:           |
Comment(by dustymugs):
 Shoot...  The second part formatted...
 root at slack64:/home/software/geo# gdalsrsinfo '+proj=lcc +lat_1=49
 +lat_2=77 +lat_0=49 +lon_0=-95 +x_0=0 +y_0=0 +ellps=GRS80
 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs '
 PROJ.4 : '+proj=lcc +lat_1=49 +lat_0=49 +lon_0=-95 +k_0=1 +x_0=0 +y_0=0
 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs '
 OGC WKT :
 PROJCS["unnamed",
     GEOGCS["GRS 1980(IUGG, 1980)",
         DATUM["unknown",
             SPHEROID["GRS80",6378137,298.257222101],
             TOWGS84[0,0,0,0,0,0,0]],
         PRIMEM["Greenwich",0],
         UNIT["degree",0.0174532925199433]],
     PROJECTION["Lambert_Conformal_Conic_1SP"],
     PARAMETER["latitude_of_origin",49],
     PARAMETER["central_meridian",-95],
     PARAMETER["scale_factor",1],
     PARAMETER["false_easting",0],
     PARAMETER["false_northing",0],
     UNIT["Meter",1]]
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1618#comment:6>
