[postgis-devel] [PostGIS] #1618: [raster] ST_Transform to SRID 3978 produce wrong results
PostGIS trac at osgeo.org
Fri Mar 2 11:39:50 PST 2012
  Reporter:  pracine  |       Owner:  dustymugs
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  PostGIS 2.0.0
 Component:  raster   |     Version:  trunk
Resolution:  fixed    |    Keywords:
Comment(by dustymugs):
 Yes.  The answer coming out is exactly the same answer as that from
 gdalwarp.  I've attached a TIFF matching the raster in your example.  If
 you warp that image with gdalwarp
 gdalwarp -t_srs EPSG:3978 test4269.tif test3978.tif
 The output matches that of ST_Transform.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1618#comment:10>
