[postgis-devel] [PostGIS] #1641: TopoGeo_addLineString: SQL/MM Spatial exception - geometry crosses an edge
PostGIS trac at osgeo.org
Mon Mar 5 02:58:36 PST 2012
  Reporter:  lrssvt    |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  medium    |   Milestone:  PostGIS 2.0.0
 Component:  topology  |     Version:  2.0.x
Resolution:  fixed     |    Keywords:
Comment(by strk):
 @lrssvt : if you want to relaunch the whole import I'll be happy to have a
 report about what happens now. Also you may want to create the topology
 with a precision that really reflects your data precision (cm? mm?) and
 see how that affects further toTopoGeom calls (they should be using the
 precision you specified at CreateTopology time as a tolerance).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1641#comment:17>
