[postgis-devel] [PostGIS] #1641: TopoGeo_addLineString: SQL/MM Spatial exception - geometry crosses an edge
PostGIS trac at osgeo.org
Mon Mar 5 07:31:45 PST 2012
  Reporter:  lrssvt    |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  medium    |   Milestone:  PostGIS 2.0.0
 Component:  topology  |     Version:  2.0.x
Resolution:  fixed     |    Keywords:
Comment(by strk):
 In that case it sounds like a bug, or a missing upgrade on your side.
 Note that the _order_ in which you add geometries matters.
 Do you have a short self-contained example reproducing the problem ?
 Actually, best if attached to another ticket, thanks.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1641#comment:21>
