[postgis-devel] [PostGIS] #1648: [raster] ST_AsRaster unexpected result
PostGIS trac at osgeo.org
Mon Mar 5 12:59:48 PST 2012
 Reporter:  jomarlla  |       Owner:  pracine
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  raster    |     Version:  trunk
 Keywords:            |
Comment(by dustymugs):
 Part of the problem here is there is nothing the PostGIS Raster devs (me
 included) can do to remedy the result you're getting as the PostGIS
 function is passing the geometry to GDAL to do the actual burning.  If you
 can, you may want to see what you get using the geometry through the
 gdal_rasterize utility.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1648#comment:5>
