[postgis-devel] [PostGIS] #1652: make docs-install runs xsltproc
PostGIS trac at osgeo.org
Mon Mar 5 18:02:45 PST 2012
 Reporter:  gdt                    |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  low                    |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
 After running make docs, make docs-install runs xsltproc.  (In my
 case, I passed BADFLAGS="XSLTPROCFLAGS=--LOSE" to make docs-install,
 so that I would find any invocations of xsltproc.)  In this case, it
 seems to be redoing the exact same build.
 gmake -C doc install
 gmake[1]: Entering directory `/home/gdt/SOFTWARE/POSTGIS/postgis/doc'
 gmake -C html/image_src images
 gmake[2]: Entering directory
 `/home/gdt/SOFTWARE/POSTGIS/postgis/doc/html/image_src'
 gmake[2]: Nothing to be done for `images'.
 gmake[2]: Leaving directory
 /usr/pkg/bin/xsltproc --param section.autolabel 1 --param
 section.label.includes.component.label 1 --param chunk.section.depth 0
 --param generate.section.toc.level 1 --param funcsynopsis.style kr --param
 admon.graphics 1 --param admon.textlabel 0 --param simplesect.in.toc 0
 --param use.id.as.filename 1 --param chunk.quietly 1 --LOSE --stringparam
 html.stylesheet style.css  \
         --output html/postgis.html \
         /usr/pkg/share/xsl/docbook/html/docbook.xsl \
         postgis-out.xml
 Unknown option --LOSE
 Usage: /usr/pkg/bin/xsltproc [options] stylesheet file [file ...]
 From "make docs":
 --param use.id.as.filename 1 --param chunk.quietly 1  --stringparam
         postgis-out.xml
 Element strong in namespace '' encountered in para, but no template
 matches.
 ERROR: xref linking to  has no generated link text.
 Link element has no content and no Endterm. Nothing to show in the link to
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1652>
